Old 06-12-2016, 12:48 AM
ed in cny ed in cny is offline
OK thanks for the responses guys, Great help. I do have a question on how am I to see if there is any movement and no movement on the shaft? I'm lost. how to see this. Can I wrench over the motor and see it from underneath? or does someone have to sit in the seat and turn the starter over? Not sure how this is verified? I don't like the idea of having someone under there (me) when someone is turning the key. My luck I'd be the hamburg under the wheels. You knew my family you'd say the same. They are great but for this I want the expert.
Old 06-12-2016, 02:35 AM
All good responses but I will share my experience. I had this happen recently on my 122 with exactly your symptoms. Creeper was in between ranges and Ended up being the roll pin worked it's way down out of the shift collar inside the creeper. You can fix this without splitting the tractor if this is what happened. You have to verify though like others have said that the creeper input is turning with the drive shaft. You can take the drain out of the creeper and put the punch up through the drain hole to hit the pin back in but it's difficult to line up and patience is necessary.
X2 on Alvy's diagnostic....but mine was on my 73. My advice is start with a visual inspection of the drive shaft before exploring the creepy gear. Start by removing the deck (if you have not done so already) securely jacking up the rear of the cub, use jack stands (if possible, I would even suspend the rear using chains) and secure the front tires. Then, visually inspect the drive line in a safe manner.
Old 06-12-2016, 10:37 AM
Berwil's Avatar
Berwil Berwil is offline
I would put a block of wood under the rear driveshaft couplers to set your phone on about 6" away. Aim your phone at the couplers and a start recording video. Sit on the tractor, start it up, put it in 3rd gear and let out the clutch (slowly) for a few seconds. Watch the video and see if the creeper input shaft is spinning. If it is, then it's in the creeper like Alvy suggested. Any video recording device could work, seems like most people have phones that take videos nowadays. Might need a drop light for better illumination.
Bill
