Old 05-28-2016, 11:41 PM
Originally Posted by MattH View Post
Tractor ran okay today, still not much reverse. I tilled for about 30-45 mins. When I was done, same issues.. Extremely hard drive lever and hardly no reverse at all. I had to push it in the shed (while in reverse). Any suggestions guys?
Did you take the tunnel cover off and watch all the linkage wile backing? You could see whether it's all moving or not. It's likely a linkage issue, your just going to have to look it all over and see what the deal is. If you don't find anything, I have seen the roll pin inside the hydro that attaches the trunion lever to the swashplate break, but it usually causes neutral adjustment issues.
Old 05-29-2016, 04:18 AM
MattH's Avatar
MattH MattH is offline
I've looked up some repairs for the trunnion and spring. Not sure what the easiest way to fix it would be yet, but I'm still learning about it.
The tunnel cover has been off for some time already.. Every thing seems to be moving freely, just tight operation... I'm kinda stumped.
1450 Dual Stick Hydro | 42" Power Angle Blade | Model 1 Tiller | Homemade Wheel Weights
RZT 50
Old 06-01-2016, 06:26 PM
kalebevans kalebevans is offline
How tight do you have that friction disc on the bottom of the speed control shaft assembly the speed control handle is bolted to? I've had that tension change on me before. If I remember right it should be adjusted to require 7-12 ft/lbs to move that handle, though I prefer it a little more on the loose side myself...
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original!
Old 06-01-2016, 06:50 PM
Tight as you want it. I don't like mine that tight. Yes, the book has some kind of spec for it.... Snug it up until your happy.
Old 06-01-2016, 09:55 PM
MattH's Avatar
The only bolts I loosened were the for adjusting neutral. After I adjusted, I tightened them pretty tight.
RZT 50
Old 06-02-2016, 12:48 PM
When I got my 169 running I had the hood and grill off driving it for the first time, and that handle was so tight I had to thump it to make it change speeds. I was going along at about mowing speed, and when I thumped it to go faster I about went over backwards! Turns out that cast iron grill is pretty necessary for holding the front down... Even with the grill and hood on it will wheelie if I get after it too quickly; adjusting that friction disc and repairing the trunnion was a good thing...
