Old 05-20-2016, 11:30 AM
Workinprogress Workinprogress is offline
Externally accessible seals replaced on pump.
Axles seals replaced.
Lower 3 pt mounting brackets built and installed.
Painted
Now onto the frame and body panels.
Old 05-20-2016, 11:34 AM
First of many improvements.
Dual spool hydraulic valve and levers just arrived.
Thanks Rays in PA.
A little clean up and fresh coat of paint it will be an great improvement.
Old 05-20-2016, 07:37 PM
twoton twoton is offline
Looks real good there Workinprogress, thanks for the pictures.
Old 05-26-2016, 08:04 PM
More parts wire brushed, cleaned and first coat of primer.
HF HVLP sprayer on way.
Old 05-30-2016, 03:21 PM
First coat of primer on all parts to be painted yellow. Rear fender needs more sanding around slight pitted area.
Steering disassembled, cleanned, greased and reassembled.
Old 05-30-2016, 05:28 PM
Sorry SGragg missed you engine question.
Last year I picked up a wheel horse 417-8 (kt17 series I I ) for cheap. Magnets in the flywheel broke free and took the stator. So after replacing the flywheel (with one from a cub) and the stator the engine runs ok. I hauled firewood with the wheel horse last fall to give the engine a workout. It seems fine. So for now this will be my engine.
Since I still need to buy a pto clutch I have been keeping my eyes open
For something else if the price is right.
Old 05-31-2016, 07:46 PM
chrismiele chrismiele is offline
I have a complete but bad kt17ii if you need any parts. Everything is there.
Old 06-11-2016, 08:00 AM
Still making progress.
Last coat of primer on yellow parts.
First coat of primer on white parts.
Really like the HF HVLP sprayer. Very little overspray and nice control but this is
My first HVLP so I have little to compare it with.
Old 06-15-2016, 08:48 PM
Angry
One step forward, two steps back!
Got up early this morning. Weather was great, no wind, temps in the 60's but warming to 75. Hung all the parts, mixed yellow paint and suited up.
Well my inexperience with spraying and poor cleaning of the gun following priming resulted in a very crappy job. Orange peel everywhere, except for a few small parts.
My biggest problem was lack of paint being applied. While the gun worked good for a minute, it went down hill fast. After examining the poor job, I totally disassembled the paint gun and found small chunks of primer in the gun. I have no one to blame but myself.
So now I need to sand all the panels and parts to remove the orange peel in the yellow paint.
Since this was my first light coat of yellow paint will the next coats help hide some of the orange peel?
Old 06-15-2016, 09:29 PM
lindstromjd lindstromjd is offline
I would wait until it hardens and then just fine-grit sand it until it smooths out. No need to break it all down and strip it clean again.
