Closed Thread
Old 04-27-2016, 01:11 PM
I had two tires on a cub that I purchased that had great tread but big splits in the sidewalls from sitting on flats. I bought two tubes and for $5 or $10 a tire, the local tire store took the tires off the rims, put the tubes in, installed them back on the rims and inflated them for me. Still riding high!
Take a little bit of time to price check tubes (ag stores have them and maybe your local tire shop will, too), call your local tire shop and see how much for their bill; shop on craigslist for something local to purchase or check with any lawnmower repair shop for some quick fix. Whichever is most cost effective to get you back in action, then that is what I would do before your grass gets out of control.
Old 04-27-2016, 06:26 PM
Wayne Wayne is offline
The best deal I can find on tubes is about $18 bucks. I've already searched Craigslist and asked the one local shop I'll deal with (I won't deal with the other) and they didn't have used tires. I will ask them how much they'll charge for installing the tube (they wanted 25 for a tube), as I don't really relish that job if its tricky or could damage my tube.
The split is radial, running parallel to the tread in the center of the tread. I doubt slime will work because I don't think it'll hold air long enough for the slime to set up. Its a pretty quick leak.
Cub Cadet 2166
Old 04-27-2016, 06:37 PM
V30crewcab V30crewcab is offline
I bought some tubes from summitracing for $5 apiece. not sure how much they are for your size, but doubt its much more. best bet is to put a wanted ad on craigs and find another set of rims and tires off something else. they used that rim and tire on everything for years.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 04-27-2016, 06:43 PM
Take it to a little hole in the wall tire place and see if they can put a tube in it for cheap.
Old 04-27-2016, 07:20 PM
Old 04-27-2016, 07:30 PM
I was quoted $12 for putting the tube in. I looked at Summit and don't see anything for less than the $17.23 tube from Sears, once I figure in shipping from Summit. So $30 bucks to get rolling, I guess, unless I decide to try doing it myself. For $12 I'm inclined not to
Cub Cadet 2166
Old 04-27-2016, 08:39 PM
If I can muscle 38" tractor tires @ my age and remove replace tires/tubes, it is a walk in the park with a little 12" tire & tube.
it just ain't a big deal, but your call.
Yes tubes have gone up in price as well as tires, thank you bozo big ears in the white house
luck whatever you choose.
Old 04-28-2016, 12:09 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
For $5 or $6 you could have tried Slime by now
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 04-28-2016, 12:12 AM
I don't need to spend 5-6 bucks. I already have some Slime. I'll take another look at it but I don't think Slime will work if it wont hold any air for more than a few seconds.
Cub Cadet 2166
Old 04-28-2016, 12:13 AM
And ruined what was left of the tire.
Have you ever broke down a tire with slime in it, then tried to patch it or put a tube in it? You can't. It softens the rubber and vulcanizes it. You can't patch it after it's been slimmed. Then, the inside is so nasty and sticky, putting a tube in is near impossible.
Only way I'd ever use that green is if I was desperate and was going to replace the tire anyway.
Closed Thread
