Old 04-12-2016, 02:40 PM
Um...It fits and works fine on my machines...
Why not??
Because that part number is made for Magneto ignition. Not a point ignition. You likely used a different part number.
Old 04-12-2016, 03:03 PM
Old 04-12-2016, 04:59 PM
mortten mortten is offline
Chris Westfall has the Cub one for $18.00
Old 04-12-2016, 05:17 PM
That is a good price for the Indak Ignition Switch.
Old 04-12-2016, 09:27 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I put a switch out of a 1086 in my quietline. I mostly did this because at the time I was working at an IH dealer and they had one in stock. I also like the IH key better. The switch is a little bigger so you have to make the hole in the dash tower larger but that was not a problem for me. This is just what I did and it worked for me.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 04-12-2016, 10:28 PM
They will work.
Old 04-13-2016, 12:30 AM
Bob95065 Bob95065 is offline
What's the difference between the switches?
Do you have a part # for the points switch?
Old 04-13-2016, 01:27 AM
The difference is a magneto needs to power to run, but you ground it to kill the engine. A point system needs B+ power. The mag style ign switch, the terminal for ignition ground the M terminal to the base when turned off.
No, I do not have the part number. Feel free to pull the CC part number and cross it, or have a parts guy (actually) do his job and find you one.
Old 04-13-2016, 07:28 AM
I actually did spend the time and look through the Ignition Switch section of the Primeline catalog. There is NO direct (drop in) replacement for the IH-61524-C3 Switch. I did see a switch that would possible work, but what was posted as far as data, wasn't totally clear.
Old 04-13-2016, 10:23 AM
drake dumpster drake dumpster is offline
thanks for the responses. I will order one at napa.
