Posting pictures on here is weird. Ill try to get better pictures in the morning.
PTO isn't slipping when you load the pump is it? Try to lift the loader and watch the pump shaft. Does it stop spinning? Does this tractor still have a PTO on it? Or has it been removed and replaced with a pulley?
Like John said, pics do help a lot. More please! |
Yes the pto is still on. I read another guy had the same problem and he said the OUT on the pump should go to the IN on the lever. And the OUT on the lever goes to the cylinders. And the other port on the lever goes to the IN on the pump. Mine right now is in to in and out to out. So I'm ganna try that when I get home
you have it plumbed WRONG!! "OUT" on pump goes to "IN" on control valve. "OUT" on control valve goes to hydraulic oil tank and from tank to "IN" on pump. the other ports on valve go to the hydraulic cylinders
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
I believe you guys have it figured out, out on one thing goes to the in on the next thing.
Kinda like extension cords, you don't put two like ends together.
I get that now. When i bought it from some guy that had 3 loaders and like 50 cubs this is how it was. But it makes sense now
I hope it works as intended when the plumbing is fixed. And I hope you post some video of that loader in motion!
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
And...... there it is. Glad you figured it out.
