You can get them from cub cadet, not sure of the napa parts number,other will probably chime in with better info on that.
There is one on each side of the carrier. You're going to have pull the axles and tubes off to get to these. They are not like the later models, no oil should be in the tubes, there's grease fittings in the ends of the tubes to lube bushings that you also will probably want to replace when you have tubes off. Any movement at the end of the axle may make your new seals leak, and check out your axles too because they tend to get worn out in the bushing area. I hade to pull my carrier out of one so I needed the orings that went on each side of the carrier plates but it's not necessary to do those unless you pull them. Here are te part numbers that I used, all sourced locally from bearing/seal shop because I didn't want to pay the CC prices. Hope this helps
Seals SKF 10049 (2) Axle tube bushings SS-3236-16 (2) These were the closest I could get, had to modify them some but very worth it compared to how much OE was O rings come in 10 pack Part number 01235
Thank you guys. I'll look into that. And a ballpark range for these would be??
![]() Quote:
