Old 02-15-2016, 05:09 PM
IHcubcadet1's Avatar
IHcubcadet1 IHcubcadet1 is offline
I've read how to time. Can I time without a light? Or does it HAVE to be done with a light. Can I try to read the mark on the flywheel?
Old 02-15-2016, 05:21 PM
There are several ways to do it.
Many of the guys use a volt meter. I normally use a test light, you can use the light to see in the hole. Attach the clip to the neg. (point side) of the coil, rotate the crank shaft, when the light comes on the "S" should be centered in the hole OR the marks should be lined up. If not move the points and try again until it's right.
Old 02-15-2016, 05:37 PM
Do you know the method with a volt meter? Thanks.
Old 02-15-2016, 05:44 PM
Same thing, except the needle moves rather than the light coming on and you have to have a separate light to see in the hole.
Old 02-15-2016, 06:44 PM
You were right. It was timing. No more knock. Timed it the right way. Thanks guys.
Old 02-15-2016, 06:54 PM
Congrats,Sam of Yosemite is your "go to" guy.
On to the next challenge.
Don't run it without an air cleaner though,might suck in some dirt.
Old 02-15-2016, 07:06 PM
I put a paper one on when I ran it. It's going to have a paper until I get an oil bath.
