Are you using 2 or 4 ply tires? I would think 4 ply would hold up better.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
I asked this same question earlier this year, and the answer is basically that there is no good solution right now. I have family that owns a tire shop, and asked them too. The options are pretty much foam it [their explanation was it wasn't really a good fit for the zero turn I wanted it for, since they could not really control to "pressure" (RE: "feel") of the tire, since I run 3-5lbs of pressure in my ags] or slime it.
I hate to slime my tires/wheels, but it turned out to be tho only option for me. I was goign to tube the tires then slime them but then realized I was not gaining anything by it, and was just spending money that I didn't need to. |
I have not had much luck with Slime type leak sealant but I just may try Gempler's Extreme Grade sealant. Some of my tires that are going flat are 2-ply rated, and others 4-ply rated. I do buy 4-ply rated tires when I replace them. Since I swap front tires/rims between my five Cubs as I need to due to flats, I have lost track of which tires are the newest and when I mounted them, and which ones came with the Cub when I bought it from somebody. Going forward, I will date mark the inner sidewall of the tires with a paint stick so I can know how old the tires are when they start leaking.
BTW - to mount the tires I'm using the Harbor Freight mini-tire changer 61179. I don't have a large enough workbench or vise to get the leverage and stability I need for the tire changer. So I bolted the tire changer to one end of a 4 ft board. I drive my car onto the other end of the board and the cars weight holds the board and tire changer in place, and gives me enough room to work. |
I have actually had very good luck with the green Slime. This summer when I was bush hogging at my Grandparents house the front tire on the Deere picked up a thorn (thought it was barb wire at first ). The tires had been tubed previously, so a plug was not an option. I think I put 16 oz in. I had to add about 10 psi a month ago. I don't mind having to add a little air every few months. I recently picked up a gallon pump bottle on sale at TSC for $20. I have fixed a couple front cub tires and 2 atv tires with it.
I try to use as little as possible. I have been mounting tires for 20 years and absolutely hate traditional fixaflat. The green stuff washes right off with water and is non toxic. I have 2 wheel barrows with Slime tubes in them and have never added air. I am a believer!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
