Old 12-05-2015, 10:22 PM
Had a typo in my last post that I missed, it should have read:
IIRC the translating tube should not turn until it gets to the end of it's travel. You may need to adjust the rubber on the end of the clevis.
That is correct, at least that's the way mine is.
Old 12-05-2015, 10:35 PM
mmclaughlin mmclaughlin is offline
I cant figure out what part this might be ?
Old 12-06-2015, 01:43 AM
On part #20 (in the exploded view in post #3) there is a nut where part #20 enters the translating tube. Inside the tube (on part #20) there is a rubber, tightening the nut will cause the rubber to crush flat and expand outward causing friction with the translating tube.
If the translating tube turns before the lifting nut (#12) gets to the end of its travel, all the parts just go round and round with the screw (#11) and it stops lifting.
Be careful adjusting the nut... too much and it will be hard on the rest of the components, including the motor and those expensive gears.
I would crank down on the bolt for the spring assist to get as much out of it as you can. Then tighten the nut on the electric lift, little by little.
Once again, lifting a snow thrower with an electric lift is probably pushing the electric lift to its limits. If you have a three point hitch, you could get a Brinly spring assist and add it to your three point hitch, that would really help out a lot.
Some of this post may be hard to understand or I haven't been able to express it well. If there is anything that you don't understand, just ask and maybe someone can help clear it up.
Old 12-06-2015, 06:35 PM
Thanks for all the help, It works great now. With the combo of tightening the nut & cranking in the lift assist.
Old 12-06-2015, 06:37 PM
Got the lift fixed now the pto clutch decided to blow apart. Back to the drawing board. At least winter isn't here yet, lol
Old 12-06-2015, 07:36 PM
Congrats on getting it working
It's better that it broke now instead of during a major snow storm.
