Thanks guys, I knew I could count on you all for some great advice!
And happy Labor Day! |
I have an Auto-Arc made by Hobart. It has adjustable darkness, adjustable delay and a switch for grinding or welding. It wasn't overly expensive but suits it's purpose.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
As a little add on to this, in addition to the Lincoln helmet that I got I added a cheater lens;
https://www.amazon.com/dp/B07BVYMZN3...v_ov_lig_dp_it Sure helps to see what you're doing. |
![]() ![]() Seriously, that is NOT a bad idea--for those of us with enough birthdays to now own a pair of "shop" glasses--I just couldn't stand the thought of bifocals and turning wrenches.
I have a Jackson Nemesis and a Hobart. Both autodarkening. Mostly use the Nemesis now, way better sight. Grind mode is OK, too.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I have a 2.5 cheater I put in my Jackson auto darkening helmet when I weld a motorcycle tool I make. I weld a 1/4" pin on the end of a threaded 10mm bolt. One stray TIG arc makes for extra work to fix the threads.
I have a Forney auto darkening. Range settings are 9-13. This was a gift. Prolly came from TSC. I used it a few times. It was a wonderful weldimg experience compared to regular old fashioned lens. It also worked great during the solar eclipse last year.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
20 years ago, I bought a Hobart auto-darkening,, it was perfect until 2 months ago,,,
![]() I replaced it with this,,, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 WOW, after 20 years,, they added a LOT of nice features to the new auto helmets,, |
I picked up this Hazard Freight special last year for around $120. It really works nice and is probably made in the same China factory that 80% of all the other helmets are made in. It looks nice with my Chinese built Esab.
![]() https://www.harborfreight.com/weldin...met-63749.html
What do you use yours for? Looks pretty small and precise.
