Old 09-06-2015, 08:17 PM
if it were me id use a gear drive and put an under drive gear set in it to make up for the taller tires, i think you'll find the hydro will feel under powered with the taller tires.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-06-2015, 09:02 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
my agway has 27 inch tall tires with a hydro,but it also has low range. perhaps double gearboxes from a jeep or small car would work
Old 09-06-2015, 09:56 PM
ford4150's Avatar
ford4150 ford4150 is offline
turned it around. looking forward to progress pixs.
Old 09-06-2015, 10:02 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Very cool! Thank you much.
I am broke, but I make it work!
Old 10-01-2015, 07:22 AM
baldy347 baldy347 is offline
How about chain drive from the original axle flange to a split jackshaft to mount your oversize rear tires? This should move drive strain from original drive line to parts heavy enough to handle the workload -and be easily adjustable ratio if you later want to change it.
Basically like a chain drive MACK truck.
I'd probably try 4 or 5 to one to start; our 12hp singles do not have as much torque as the 60ci. four cylinders in full size CUBS. A simple flange with a stub shaft to bolt on the wheel flange should get you started.
wayne
Old 10-01-2015, 07:41 AM
Thanks wayne
Old 11-22-2015, 06:47 PM
Got a lil more done. Still in mocking stages. Hope to get a lil more done tomorrow.
Old 11-22-2015, 07:21 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Originally Posted by crossingcrown View Post
Attachment 69901
Must have put Helium in the tires to keep the tires lite.
Old 11-22-2015, 07:34 PM
You know it.!! Is there a i can make sure my pics come in the right way?
Old 11-23-2015, 12:28 AM
Here you go...
