Old 08-18-2015, 12:28 PM
Yes it does but on most models it puts it into the air cleaner or intake system to be burned as a pollution reduction device.
It is possible that it is malfunctioning and putting excessive oil into the intake system
Are you having to add large quantities of oil to the crankcase?
Now let me say I'm not familiar with your model engine, so hopefully someone who has BTDT can help more.
Old 08-18-2015, 08:49 PM
irelandchad irelandchad is offline
Default New to me
I have not had the tractor long enough to know how much oil it is burning. Been dry here and haven't had to mow much. I just don't under stand how the reed would cause oil burn since.it let's air out of the case under normal conditions.
Old 08-18-2015, 08:53 PM
The vent tube from the crank case is directed into the carb intake, take the air cleaner off and you'll see a hose aimed at the throttle intake.
Old 08-18-2015, 09:23 PM
j4c11's Avatar
j4c11 j4c11 is offline
I guess that's an easy one to diagnose, take the air cleaner off, start the tractor, see if it's spitting oil out the tube into the carb.
Old 08-20-2015, 05:10 PM
Default compression
Left cyl is the low one
Old 08-20-2015, 05:12 PM
Default plugs
Dark one is the left cyl.
Old 08-20-2015, 05:14 PM
My guess is that it's head gasket time. Just my 2 cents but I'd pull the engine and replace both of them.
Old 08-20-2015, 05:15 PM
Default breather
After mowing today did a little trouble shooting. Left it idling and removed aircleaner. Took breather hose out of carb. Moved throttle from WOT to idle a few times still smokes the same.
Old 08-20-2015, 05:23 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
as Sam said,pull the engine and replace both head gaskets. while its out i would clean any debris off the engine and replace both crank seals.a service manual for the machine/engine would be best to have on hand. make sure to replace the spark plugs after completing repairs
Old 08-20-2015, 06:58 PM
Default Overhaul manual
Anyone have an overhaul manual PDF or hard copy?
Are these motors know for crank seal issues? I don't think I'll have to remove the motor for just head gaskets.
