			Sam would a ceramic coating like they use on headers help keep the heat down?
	1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374  |
	2264 with 54 GT deck 1641 AKA Black Jack with a 402-E Haban Sickle bar mower JD317 dump truck BX2670 with FEL  |
			No doubt that would help. I think some header wrap on the tail pipe will do what I need to do. I have a temporary pipe on it at the moment and ran it for a while, seems good. Serviced the engine, then I did a little cleaning on it. First pic shows the warped hood with the exhaust exiting through the grill. Second pic is my temp exhaust. Remainders are after a little cleaning.
			Lookin' good!
			Ya know all done up like that those newer 2xxx/3xxx series machines don't look half bad. Careful Sam, you may get hooked on em!
	-Ryan
			looks like a nice machine,is there a way to route the exhaust out the bottom like your temporary pipe is routed?
 http://www.jegs.com/webapp/wcs/store...erm=555-319201 I'll cut it and weld it so that it will exhaust out the bottom. The pipe should be a tight slip fit over the existing pipe from the muffler. Once I get it all the way I want it I'll weld it together.
			Sam,
			I agree with your assessment. My 2186 is a good mower but the twisting and rough ride and general lightness of the entire machine isn't up to the old machines and it was never intended to be. I did as you suggested, I got it so I would have a standby 18hp for my 1864 and have a nice mower in the mean time. It does have a nice tight turn compared to some of my old ones and the deck does a good job.
	Randy Cubs: 71, 72, 127, 149, 1440, 2186 and 1864 John Deere 110 round fender John Deere 140 H3 Sears: GTV16  |
			Good job there Sam
			![]() It's almost ready to leave the nest, and fly away
	Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key!  |
