Old 08-10-2015, 12:03 AM
coinman66 coinman66 is offline
Shake and rinse....
Then I use a shop vac on "blow" in the fill hole while sitting in the sun. Not an exact science by any means.... but overall effective.
My arms get tired of shaking though..... You got kids?
Put em to work. Like!
Old 08-10-2015, 12:18 AM
ford4150's Avatar
ford4150 ford4150 is offline
I used the gravel method in the past. Duct tape it to my cement mixer, then turn it on.
Old 08-10-2015, 08:11 AM
I've thrown in a box if 1/4" square nuts and did the shake, shake procedure.
I'm not a big fan of internal coatings, see a few go bad and make a real mess.
Acetone was the only thing that dissolved the coating inside.
Maybe it was an isolated case.
Old 08-10-2015, 08:18 AM
I have heard Coca Cola works good if you let it set overnight.
The "Works" toilet bowl cleaner works real well on rust. About 20-30 minute soak. Rinse well and neutralize.
Old 08-10-2015, 08:59 AM
rbarri2's Avatar
rbarri2 rbarri2 is offline
A piece of chain can be used to dislodge stuff. Keep one end on the outside and just pull it out when finished.
PLEASE CONTACT ME BY CLICKING MY USER NAME ABOVE.
1968 Cub Cadet 124 with deck and #2 Trailer
1965 IH Scout 80 Champagne Edition
1968 IH Travelall 4x4 and factory PTO winch
1955 IH Refrigerator
Old 08-10-2015, 09:41 AM
I've used nuts and muriatic acid to remove the rust. Then Kreem to seal it after.
https://www.google.com/#q=kreem+kit
Old 08-10-2015, 01:34 PM
johncub7172's Avatar
I was amazed at the amount of rust, ect., that the nuts method removed. I added a bit of gas to the procedure, shook and rinsed many times. While your there, now would be a good time to reseal the tank nipple, and repaint the tank if desired.
Old 08-10-2015, 05:54 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Maybe use gravel but metal nuts shaking in a container with some gasoline in there too?
No thanks.
Dad use to use the gravel method, dry pea gravel.
Then he stuffed/wedged the tank into the rear wheel of another tractor.
With foam cushions and bungee cords to the tire chains.
Then sent me out to mow the lawn(s).
A 12hp tumbler.
Old 08-10-2015, 07:38 PM
twoton twoton is offline
X2 on the Kreem.
Old 08-10-2015, 09:02 PM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
X2 on the Works
