Old 07-29-2015, 09:36 AM
ford4150's Avatar
ford4150 ford4150 is offline
Exactly correct. Drilled u-joint and shaft for 1/4" spirol pin.
https://sweetmfg.biz/product.php?productid=2603
Old 07-29-2015, 09:43 AM
I've thought about using the same joints more than once. I was a little concerned about how long they will last and the lack of a grease fitting. Guess you will be able to answer that. I have a couple sets of them from my race car days sitting in a box. Please keep us posted on how they work for you.
Old 07-29-2015, 09:49 AM
ford4150's Avatar
Will do.
This one gets a Johnny Bucket Jr. I don't expect to ever run wide open throttle. I asked JB to build one with a delete for the lift actuator. I was going to use the hydraulic lift on the 782. They said no. So, I removed the hydraulic lift on the 782 and sold it.
Old 07-29-2015, 09:59 AM
rwairforce rwairforce is offline
That driveshaft looks so simple compared to the one used on the Cyclops. No expensive grease boots, balls escaping across the floor, tiny rubber seals, etc.
I think I should have went this route when I had mine out replacing the boots and fan. I like simple.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 07-29-2015, 12:11 PM
garrynok's Avatar
garrynok garrynok is offline
Smile
Good looking build. I was pretty picky when I started putting my 782 back together and a year later it still looks pretty good. But I figure, hey, it's a garden tractor and they are going to get dirty. Still, if I built another one, I'd probably do it the same way.
Garry
Old 07-29-2015, 12:31 PM
ford4150's Avatar
Nice looking 782
Old 07-30-2015, 07:14 PM
garrynok's Avatar
So what did your Vanguard come off of...or is it new?
Garry
Old 07-30-2015, 10:48 PM
ford4150's Avatar
It's a 20hp that was on a mower that caught fire. Not sure what brand mower since it wasn't with the engine. To get it running I replaced the voltage regulator, coils, stator and fan. Cleaned the carb, adjusted the valves, replaced some wiring.
The seller threw in a starter and fuel pump.
It was pretty dirty. Cleaned it up, put in new spark plugs, put it on my test stand and it fired right up. Has good compression.
Don't have much money in either the cub or the engine. Got lucky this time.
Old 07-31-2015, 07:09 AM
It looks really nice so far, personally I like the sound/smoothness of the opposed twins.
Has anyone re powered a wide frame but not a spread frame,
I.E. (14-1650) with a vanguard and been able to put the side panels on?
That would make those old shakers smooth,with newer engines
Old 07-31-2015, 09:23 AM
yes it is, guess its time for a new wife.
Agreed. Life's tough. IH's are red.
