The pump drives everything. Forward and reverse is a simple control valve.
A little paint, a little Bondo, it will look like this,,,,
http://www.onlycubcadets.net/forum/s...d=1#post339149 |
Be good for snow plowing! Or with a 3pt working in a garden.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
The red ones seem to be the preferred ones to articulate....
J this pump is big 3 stages 1st section has what looks like a trunion shaft sticking out of it with linkage to the control valve 2nd stage has hoses running front and back to power trencher stuff 3rd stage is a small pump to run power steer and such
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Sneak up on the Case garden tractor guys and 'borrow' the rears out of a couple of hydrive 446's or 448's and you would be good for 10mph.
This should be an interesting project! ![]() ![]() ![]()
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all
I remember Methos testing these with a big electric drill,, maybe you gotta give the hydraulics a try. Put the machine up on jack stands, all wheels off the ground,, spin the pump, see what happens It might put a smile on your face,,,
Specs call out 3.8 mph only problem I'm seeing is the second stage of pump I see no need for in my case unless I leave it there for a rear pto could have it spin a motor to run something I guess looking at pump I don't think I can remove that section. The machine has what kind of looks like a transfer case or drop down box from drive motor to axels would love to see of I could make a cub hydro fit to it wouldn't be easy but I think it could be done.
