Nice work,it should give you years of trouble free service.
Up to 534 and counting... I give up updating my profile! |
Solid motor mounts with hardware
Impressive project! VERY nice... Cudos!
Patrick 75 & 76 Cub 1200's 44" decks & front blade Original Service Manuals |
I bought one of those batteries too. Great batt. for the $$.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I made a battery hold-down yesterday (the battery is just a little too high for the original one to work) to replace the temporary bungee cord field-expedient job. I used two 3/16" x 5" galvanized bolts from Home Depot, some hex nuts, a few lock washers and flat washers. The bolts went through the two 1/4" holes in the top of the frame on each side of the battery, held in by a flat washer top and bottom and a single nut and lock washer. I made a strap out of 1" wide aluminum bar with a hole on each end for the bolts, and used a single flat washer, lock washer, and hex nut on each side. Works great.
