Old 06-26-2015, 11:00 PM
bocephus1991's Avatar
Start with this. Point gap will vary. This is how I set mine.
http://www.onlycubcadets.net/forum/s...ghlight=Static
Brian
Old 06-27-2015, 01:41 AM
Originally Posted by coinman66 View Post
Got a weak yellow spark at the points? Won't start?
Is that a statement or a question? Spark belongs at the plug, not the points. If your looking for spark there, your looking in the wrong place.
Old 06-27-2015, 02:40 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Heck with points. Heres whatchya do...
You will need 480 3phase for this 1.
Hook line 1 to the block.
Hook line 2 to the spark plug
Hook the wild leg to the negative side of your coil.
Turn the key to "On"
Throw the disconnect and it will run like a streak of lighting.
If that doesn't work i have no idea what will
Old 06-27-2015, 02:43 AM
cubby102's Avatar
cubby102 cubby102 is offline
Yup. I needed that after work tonight!!!!lmao only problem is now I'm curious
Old 06-27-2015, 10:11 AM
coinman66 coinman66 is offline
Spark plug has spark. Huh, I'm seeing spark at points? Maybe that's what's wrong?
Old 06-27-2015, 12:28 PM
RV-ERR RV-ERR is offline
Default Points
COINMAN66 I am not the expert here but yes you will have spark as points open and close with key on and no you do not have to push or pull any thing just rotate engine [with key off ] till points gap is greatest adjust to 0.20 this is close enough that engine will run unless you have other problems. GOOD LUCK!!! CURT
Old 06-27-2015, 12:52 PM
Thanks all. I got her running again! Appreciate all the help! Except, seems like it gets hot and when I shut it off it backfired a little. During restoration maybe I shouldn't have painted cooling fins on top of engine head?
Old 06-27-2015, 01:24 PM
Terry C's Avatar
Terry C Terry C is offline
No you shouldn't have, better get it off
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-27-2015, 01:30 PM
Oh great. Always something.
Old 06-27-2015, 02:46 PM
Gapping the points is not how we set them. We about this all the time. We are trying to avoid telling people to gap points. That is why we have all the info on how to set timing.
You have bigger problems than paint on the head. More than likely you are running too lean, and if you didn't follow the directions given in this thread on how to time the engine, then your timing is off. Did you or did you not set the timing? Have you tuned your carb? And I don't mean set it to the starting point that the book gives..... did you TUNE it?
