if you are hearing the front pto spin to a stop from the seat, you need to replace the bearing in it.
I don't think its the PTO, because since I have had the mower, the deck has not been on it. So nothing with the PTO is any different. Unless the bearing is now bad based upon what Double07 had said?
I'll try to take a look at it tonight and see if I can find out where this sound is coming from. I'll also look through the grille with a flashlight and see if I can see the PTO spinning, and see if that's it as well. Thanks again for the feedback, |
Look out, she's gonna blow!
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
And I've got "a good engine"
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
I don't think it's the PTO anyway.... Quote:
![]() OP: If you aren't using the PTO (PTO driven equipment attached) you should leave it on. It's hard on the button/clutch thro out mechanism to run the engine with it disengaged and no load (belt) on it to keep it from spinning. Even the owners manual says that IIRC. I'm still sure your hearing compression air releasing and it's nothing to get concerned about, but it's good to check things out if the noise is new. |
I didn't realize the early machines didn't have a brake on them. I've never seen one that didn't.
