Old 05-29-2015, 07:43 PM
Ryan,you are correct, too bad,but then I would not have bought it so cheap.
Up to 530 and counting...
Old 05-29-2015, 10:42 PM
sawdustdad's Avatar
Upside down blades are capable of breaking a connecting rod? Really? I don't buy it. How is this any more load on the engine than heavy grass, heavy snow, etc.?
Old 05-29-2015, 11:20 PM
he strikes again.....
You are the man Lew. Nice looking tractor
Old 06-01-2015, 05:06 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
Lew has the tri state area covered,and i,m sure he payed below "Lew Book Value"
Old 06-01-2015, 06:39 PM
Thanks guys, no progress yet....
sawdustdad...It would work harder because it is trying to lift the tractor off the ground like a helicopter.
Old 06-02-2015, 07:51 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I can see how the blades might stop really quick when they would otherwise shave a tree root instead.
But you would think the belt(s) would slip before a crank or rod would break.
Old 06-02-2015, 08:50 AM
Ash_129 Ash_129 is offline
If trying to abruptly stop the crankshaft by means of a belt around the PTO results in breaking the connecting rod, I'll be the first to just give up on my Cub Cadet and shove it down the nearest river bank.
Seriously, if that could even remotely be the cause of the connecting rod breakage, then that rod was going to break anyway. Backward blades or not.
Nice 108, otherwise.
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 06-11-2015, 06:48 PM
Sounds like the general consensus nulls my guess of how the rod broke...
So today I pulled a replacement k241 out of a 70,and cleaned up the dirty engine area,I have a good k161 to re power it.
This is an early production 70,it has a different clutch arm with no notch for the steering column.
It also has a thinner axle, and a different front cast piece.
The T.O. bearing was always quite so ,it will get a new disc,trued up plates and a new teaser spring.
The k241 will re power the 108.
I will prolly have to do the same in it also.
Old 06-11-2015, 07:30 PM
Nice Lew. Nothing like PBR and PB blaster to make the day go by. Cool info on the early 70 too. Wanna share what your brushed on concoction is to make shiny paint? Solvent?
PS don't forget the muffler spacer like you tell everyone else
Old 06-16-2015, 03:58 PM
Well after a few days work, it is back together. New clutch and related products.
Runs and drives very well, I will put a mower deck on it and use for a while.
