Old 05-16-2015, 07:35 AM
amflyer amflyer is offline
pm replied to
Old 05-16-2015, 10:26 AM
The pin I bought as a replacement on the engine end of my drive shaft was a solid dowel pin last time i needed one. Get a few. that way when they break or fall out you'll have more. Bolts are a cheap farmers way out.
Old 05-16-2015, 01:49 PM
Originally Posted by DoubleO7 View Post
Just so you know...............
The Spirol Pin (a name brand) is shown at top.
Also known as a coiled spring pin.
Lower left is a dowel (solid steel pin).
Lower right is a spring pin (but not a Spirol/coiled spring pin).
The last pic shows HD, Med. and light duty Spirol/coiled spring pins.
Cub Cadets used the medium one with 2-1/4 revolutions of metal.
Great post Double 0!
I believe his post should be enshrined in the tech or faq section somewhere.
Old 05-16-2015, 06:06 PM
Found two IH pins at the show today, if everything else is okay should be in business. I wanna press the pin in the shaft out of the tractor but not sure how I am going to get it back in??
