Roy
Here's the deal, if you send a chip into the pump chances are you'll be buying a pump, and another filter. Not worth the risk. Just for your info the thread size is 3/4-16. From the Wix filter site. Product Specifications Part Number: 51410 UPC Number: 765809514102 Style: Spin-On Hydraulic Filter Service: Hydraulic Type: Full Flow Media: Paper Height: 3.79 (96.26)* Outer Diameter Top: 3.66 (92.96)* Outer Diameter Bottom: Closed: Thread Size: 3/4-16 By-Pass Valve Setting-PSI: None Beta Ratio: 2/20=6/20 Burst Pressure-PSI: 325 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21 ( )* denotes metric Gasket Diameters Number O.D. I.D. Thk. Attached 2.729 (69.32)* 2.415 (61.34)* 0.2 (5.08)*
Yeah, you guys are right. I'm just being too frugal in the wrong places.
