Old 04-18-2017, 04:19 PM
rudedawg's Avatar
rudedawg rudedawg is offline
Default asking for wiring help
I realize this is an old thread but I like the solenoid relay set up. I would like to do a similar set up for my Cub Cadet 2166 to add a switch and relay to the electric pto clutch but am not overly talented at wiring and am asking for help and/or diagram to wire the relay up. Thanks in advance, RP.
Old 04-18-2017, 05:00 PM
I don't like to see mechanical relay mounted on a engine where the vibration is a lot more than on a chassis.
But that just my .02
Old 05-19-2020, 08:38 PM
Roadstar01 Roadstar01 is offline
I finally came across your post I could have used it a few years back I've been limping this 2284 along with the solenoid pushing forward but no turn of the Armature. After various troubleshooting I think I'm going to try your solution but there were no pictures have they been removed can you repost them by chance or send them to me?
Old 05-20-2020, 07:05 AM
ten characters
Old 05-20-2020, 08:04 AM
Back in the day, Henry Ford said don't design something to make my cars more complicated, design something to make them less complicated.
Why put a band-aid on a wound when you can heal the wound and eliminate the band-aid?
Repair the problem or problems, and get on with keeping it simple.
Old 05-20-2020, 08:07 AM
Couldn't agree more.
Old 05-20-2020, 10:08 AM
Yep it sounds simple to just fix the original problem but it's a recurring issue with the cyclops series and Cub even came out with a relay upgrade. This is a simple cheap cure.
Old 05-20-2020, 10:23 AM
You can take your Cub to a $100/hour guy at a shop and maybe spend a few hundred or you can spend $10 and fix it yourself.
I'm a cheap skate and not all that great on electrical stuff and that's why I have three Commands hot wired and another one for my neighbor!
Old 05-20-2020, 04:27 PM
A man after my own heart.
Old 06-08-2022, 04:04 PM
ohioguy ohioguy is offline
I have the same issue on my 2284. Based on the explanation of the cause what would the direct solution be, finding the cause of the voltage drop?
I could use the pictures also, I like the solution!
