Thanks for the progress pics, Pat!
I really hope you didn't mess up the hydro by not capping the ports and then not just washing it, but painting it as well....
I had tape over the lines when I washed it. I plan to change the Hytrans anyway.
Pat Benner Haskell OK Keep the Deck down and the Throttle open!!! |
Did you leave them covered when you painted it, too? If you got anything at all in the charge pump, you risk destroying it. It doesn't take much. I would also take some laquer thinner and remove the paint from the bare aluminum part of the hydro so it can cool properly.
I was careful when I painted around it. I may do that, there is very little overspray on the tranny. I thoink with the oil in the fittings it shouldn't stick to anything. I plan to change the oil anyway.
Since this is going to be my FEL tractor I plan to switch the steering column for an upgraded 3 turn column. And do the front spindle upgrade. I have seen a few farm tractor break the spindles from to much load on them.
I will then have the old column upgraded and I will install that in my 129 when I tear it down.
Well took the frame down and washed it today.
Got part of the frame painted as well.
What's the easiest way to remove the hydro shift lever so I put a new decal on the dash tin?
I have the set screw loose.
After looking at the trunnion it will need a little work on it before I put it back together.
Good work! your tractor is comming along very well! i realy like your chicken coop. going to have my own chickens going on soon!
