Old 04-20-2015, 03:42 PM
Originally Posted by 13thstreetgti View Post
When the deck is down it is nice and level with both gauge wheels being equally spaced above the floor.
That Tells me that your leveling is correct, or at least even.
So how does it look as it is rising to fully up position?
That should be a clue as to lift arms being ok and not having a sheared pin.
I'm with the broken pin crowd.
Old 04-20-2015, 03:57 PM
Terry C's Avatar
Terry C Terry C is offline
I would say pins too but why does it only go crooked when being raised?
Something is making it level out when lowered. Are you sure nothing is holding up the low side allowing the high side to "catch up"?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-21-2015, 09:05 AM
13thstreetgti 13thstreetgti is offline
Rechecked the spirol pins and confirmed they are both in good condition.
Old 04-21-2015, 10:09 AM
Berwil's Avatar
Berwil Berwil is offline
How about some pics then. Views from the low side when it is up and down focus in close so we can see the action of the lift arms and deck hanger.
Bill
Old 04-21-2015, 09:14 PM
ok,
so you drove them out and they were not broken?
Old 05-04-2015, 05:32 PM
Just wanted to update in case anyone else had this problem.
The spirol pins were all fine. It ended up being that the non-adjustable lift link was too long, and that even with with the adjustable lift link set at its "longest" position the deck was still being pulled predominantly by the adjustable lift link side thereby cause the deck to the tilt.
After some research I found out that there were various non-adjustable lift link lengths (I actually bought two sets and found out there are at least three different lengths.
Using one of the shorter non-adjustable lift links I was able to get the deck to raise and lower properly and have what seems to be the average clearance under my 44A deck when the deck is raised to maximum height.
Old 05-04-2015, 05:59 PM
Thank you for taking the time to reply, it helps others.
