You have replaced ingition parts rebuilt carb and the miss is still there. So I would check the valves next. Years a go when gas was cheep and hp was king. Had an engine that could not find the miss in untill l hit the pistion with the intake valve. Releasing all the important fluids. Follow by the $$$. So now its check compression after other have been checked
The light was steady when I timed the engine.
The condenser is new. I will get a new plug and wire. I tried another coil with no change. I'm only leaning towards carb because it's the one part of the system that I don't fully understand how to conquer just yet. I know it's a simple device, but I feel like I'm going in circles with it. thanks, I'll get the video asap
PLEASE CONTACT ME BY CLICKING MY USER NAME ABOVE. 1968 Cub Cadet 124 with deck and #2 Trailer 1965 IH Scout 80 Champagne Edition 1968 IH Travelall 4x4 and factory PTO winch 1955 IH Refrigerator |
![]() Quote:
The second video demonstrates the issue better.
The engine was cold in the video. vid 1 https://www.youtube.com/watch?v=SG09...ature=youtu.be vid 2- this is with the throttle just off idle https://www.youtube.com/watch?v=X6DU...ature=youtu.be thanks
Is your throttle shaft tight? Mine blubbered off idle when the throttle needed new bushings.
![]() Quote:
![]() Quote:
It's a new carb and the throttle shaft is tight. Loose rod? Crank bearings? I hope not.
Put piston at TDC on power stroke remove plug add air check for air leak out intake or exhaust leak poor compression out engine breather rings not sealed compression test
![]() Quote:
I'm about to be out of pocket and don't have a smartphone, but I look forward to all of the feedback. Thanks again.
My 149 had something similar happen to it after I rebuilt and re-adjusted the carb settings.....and after new piston, rings and removal of the balance gear. Drove me bananas, too. Come to find out it was a little arc between the condenser and engine tin. As soon as you heard the "miss", you could see the arc. I haven't read where anyone stated this yet and hope that is all it is for you, too---simple fix.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
