Old 03-23-2015, 07:16 AM
red211's Avatar
red211 red211 is offline
Do the lower bolts need a shim in between the mount? I swapped one the other day and it did the same thing. I had an extra that the windings in the case came apart so I just robbed the end off it.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 03-23-2015, 01:54 PM
Feoe.RL Feoe.RL is offline
Thanks for the adice Mike ill keep that in mind when mounting it.
Old 03-23-2015, 04:02 PM
Calvins66Cub's Avatar
It will either need to be tig welded or replaced.
Craig made a new one for his starter / generator
http://www.onlycubcadets.net/forum/s...ad.php?t=36647
Thanks Jeff & Alvy! Mine was cast iron.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 03-23-2015, 05:12 PM
Merk Merk is offline
Originally Posted by mickb72 View Post
Hello, and when you get it fixed, don't tighten those end bolts to tight. The adjustment bolt will hold the belt tight. Mike
You want the bolts tight. They will work themselves out and cause the problem Feoe.RL has.
Project Uncle Dick
Cub Cadet 70
Old 03-23-2015, 05:17 PM
+1 ive seen many s/g missing a bolt from not being tightened.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-23-2015, 09:38 PM
Im guessing this is where locktight comes in handy?
Old 03-23-2015, 10:02 PM
Nope just a lock washer. 👀
Up to 534 and counting...
Old 03-24-2015, 05:12 PM
Well like the man said "it ain't pretty but it should hold" $30 fix hopefully he's right.
Old 03-24-2015, 05:49 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Good fix! This isn't a beauty contest but I have seen a lot more worse with low weld penetration hanging like bird poop!
Gilles.
1963 100 (red)/in storage
Old 03-24-2015, 06:53 PM
You got a good point there OldSkull. This guy was very highly recommended so im sure it couldn't have been done any better. I will keep ya'll updated on the k301 rebuild. I will be posting up many more pictures on my profile.
