Old 04-09-2010, 07:41 AM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Yes, any 12X manual will do, as far as the engine disassembly/reassembly goes.
And pay attention to detail....it's the little things that matter with engines.
My time is valuable to me, so I refuse to do things twice...and as far as I'm concerned, an engine should not need to be taken apart more than once in a lifeime....well, depending on use.
Example: my cub was well used when I go it, so if it lasted 42 years without needing disassembly, then when I rebuild it, I shouldn't see it needing rebuilding until I'm 73....another 42 years.
Fly Fishing is not a sport...It's a way of life.
Old 04-09-2010, 08:23 AM
You can also download the engine manuals for FREE from www.kohlerengines.com .
Old 04-09-2010, 06:32 PM
Merk Merk is offline
The motor HAS to be connected to a motor stand or the tractor frame before I will start it. Motors will move around on a workbench when they are running. Try catching a running motor as it falls off your workbench. Hopefully the hot muffler, gas or a rotating shaft doesn't hurt you.
by johncub7172
sounds like you and me are in the same boat. "Merkel" would know all this secret stuff.
The only "secret stuff" I do/use is read the manual and have the proper tools and gauges to do the job. I spend most time measuring, cleaning and measuring. You notice I mention measuring twice. If I don't understand something I will ask someone. I used to teach a class on small motors. The first thing my students learned was:
To Me there is no such thing as a dumb question-the only dumb question is the one you don't ask.
Get a correct Kohler manual if you are working on a Kohler motor.
Get a correct Cub Cadet manual if you are doing work to your Cub.
Old 04-12-2010, 07:42 AM
cubby123's Avatar
cubby123 cubby123 is offline
Ok, I downloaded the manual to research it. BUT, I found out something bad this weekend that I didn't notice before. I set the engine on the workbench on its side under the light, and as I was inspecting the block, something bad struck me. On the bottom of the cylinder there is a 1 1/2 inch by 1 inch of the cylinder missing at the very bottom. Could this be why Cub won't run?
if you want a real tractor, you need a CUB CADET!!
Old 04-12-2010, 09:51 AM
Can you post a picture of the suspect area?
Old 04-12-2010, 10:03 AM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Mine had a chunk missing too. I've rebuilt it, but I still haven't started it yet (waiting to finish up the rest of the tractor now that warm weather's here).
If you do use it, be sure to round off the sharp edges with a die grinder.
Here's a link to what mine looked like: http://www.onlycubcadets.net/forum/s...ead.php?t=1749
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 04-12-2010, 10:34 AM
Here's a link to what mine looked like: http://www.onlycubcadets.net/forum/forumdisplay.php?f=9
Doublecheck your link there...I got a list of forum posts..
As long as the missing chunk is down below where the piston normally rides it won't hurt.. If it is where the rings hit, it is junk, if it is where the skirt rides, it is a judgement call.
Old 04-12-2010, 10:46 AM
cubby123's Avatar
Hmmm thanks Rhoderman for the thread. I feel relieved now too lol. It isn't as wide as that but maybe as tall. I'll try to get a pic of it. So I'm going to continue to get that cylinder in it honed. My uncle could probably do it for $5 for me. Mine also threw a rod. When I first opened up the engine and took off the oil pan when I suspected a blown rod it was way worse than blown. It was BLOWN. So I will get that grinded down also. Thanks Rhoderman again. Made me feel better bout the engine lol.
Old 04-12-2010, 10:19 PM
Rhoderman's Avatar
Fixed the link. Don't know how I skrewed that up... Thanks for pointing it out though!
Cub Cadet 122, 126
