Old 01-19-2015, 05:07 PM
Group_44's Avatar
Group_44 Group_44 is offline
That gearbox is from a QA36/42A , it has 4 mounting holes. The correct plate for that gearbox should have the mounting holes for the box slotted for side to side adjustment. The plates are different between the QA36/42A and the QA36/42. Take a look at one of the online parts suppliers like partstree at the two different blower mounting systems, you'll see what I'm talking about.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 01-19-2015, 05:10 PM
Seems he has a "Hybrid" snow thrower.
Maybe this would help....... QA36/42 Installation Manual
Old 01-19-2015, 05:16 PM
Originally Posted by DoubleO7 View Post
That accommodates the belt tensioner pivot/anchor eyebolt.
Yes it does.
Does not the pulley hole in the tractor plate dictate the outer plate orientation?
And also disallow mixing of plates from QA__ to QA__A if there is a difference?
Those are the things I'm not sure of, but I believe either/or of the gear box mounting plates can be bolted to either/or Quick Attach bracket. I'm also thinking that if the gear boxes are bolted to their correct plates, the input shaft on the two gear boxes will not be in exactly the same location with respect to where they end up once the gear box plates are bolted to the Quick Attach bracket. (that should be clear as mud)
What if the gearbox input pulley is different and bigger than original?
And how come O.P.'s 127 does not have the QA latch assembly?
The pulley thing is entirely possible.
Hard to tell from here but it doesn't look like there is any evidence that the frame in the picture ever had the QA latches. Could it be a frame from a 123 with a 1X4/5 or 1X6/7 grill shell bolted to it?
Old 01-19-2015, 05:23 PM
I noticed the elongated gear box mounting holes in the exploded view. I did a refresh on my QA 42A this past fall and I'm not saying it isn't true, I just don't remember the holes being elongated, it is quite possible that I just overlooked it.
Unless someone else has a better idea, I think someone should suggest that he loosen the gear box mounting bolts and try to slide the gear box to the left.
Old 01-19-2015, 06:13 PM
hondaxr hondaxr is offline
Default More pics
I took another picture of the front of mounting plate and looks to be a little room where I can move to the right(FACING FRONT OF TRACTOR) to move the belt enough so it's not touching(RUBBING)! My gear box pulley is 4"OD, hoping that is the correct size pulley! Thanks!005.jpg
Old 01-19-2015, 06:42 PM
ironman's Avatar
ironman ironman is offline
Mountings from the manuals, first is QA36 - 42, second is QA-36A-42A.
First one is narrow frame only, second fits wide or narrow.
You would need the correct (wide or narrow) lift bracket and pivot rod.
Old 01-19-2015, 06:49 PM
Originally Posted by hondaxr View Post
I took another picture of the front of mounting plate and looks to be a little room where I can move to the right(FACING FRONT OF TRACTOR) to move the belt enough so it's not touching(RUBBING)! My gear box pulley is 4"OD, hoping that is the correct size pulley! Thanks!Attachment 60869
Seems like you figgered it out,it will move to the right as the holes are elongated.
That is the correct frame ,it has the notch cut out for the points cover removal,you cannot see the qa as it is behind the mounting bracket.
Up to 530 and counting...
Old 01-19-2015, 07:07 PM
Default Hmmm!
According to manual this blower QA-42 (NOT A), is intended for 70,71,72,100,102,104,105,122,123,124,125 for whatever reasons! Mine is 127! This came off a 123! But I will make this work and post more pics! Thanks to all!
Old 01-19-2015, 07:14 PM
It's for any NF tractor. It is listed to fit a 127. You must have looked in the wrong place.
Old 01-19-2015, 08:16 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The snow thrower manual for the QA36/42 hosted by OCC is too old (6-1968)to show the 126, 127 usage.
The gearbox mounting plate is indeed for a 3-bolt box, you can see the square head bolt hole.
