Old 01-15-2015, 11:52 PM
As soon as Ryan (Jimbob) gets them resized for me, I made diagrams of the PTO circuit in all 3 stages. Off, Start, On. Color coded them so it helps. Sorry, I don't know how to resize pics.... so Ryan is gonna send them back BIGGER. Hang tight! Pics to come.
Old 01-16-2015, 05:05 AM
If it's your bearing going out you can replace it. Just search for "6206" in the search box. Good luck and let us know how it goes.
Old 01-16-2015, 09:58 AM
I should say, I agree. Sounds like your bearings are going out. But, if you don't have power to the clutch when you should...... you may have a wiring issue. I'm still trying to get the pics. We're having "technical difficulties".
Old 01-16-2015, 01:18 PM
Ok. First off, I will apologize for the quality of the pics. Best we could do so quickly. If you click on them, they link to a larger pic you can read better..... Kind of. At least you can zoom in.
1864 Complete Wiring:
For the Next 3 pics, I have eliminated all circuits besides the PTO. All switches are as follows: Key on. Reverse switch NOT activated (closed). Seat switch closed (sitting in the seat). PTO switch will be described.
Also note: the seat switch is a dual switch. It contains a N/O switch for the PTO and N/C switch for the "Run" circuit. On this machine, you have to either be sitting in the seat, or the brake has to be set to get off the machine. It may be bypassed on yours. Brake switch is also a dual switch. We are only concerned with the seat switch for the PTO circuit.
PTO Switch "OFF":
PTO Switch in "Start":
PTO Switch "On":
Like mentioned, sounds like you have a bearing failure and an electrical problem.
NOTE: To test the PTO circuit, you can do it with the engine off, key on, then place something in the seat heavy enough to activate the seat switch. Then can test. Hope this helps and good luck.
Old 01-16-2015, 06:16 PM
Nettelec Nettelec is offline
Wow, the diagrams are great. I noticed the reverse micro switch is missing the lever part to the switch, it is somewhat broken it seems. That may be where my electrical issue is. Hopefully I can find time this weekend to dig into the bearing and the wiring. Thanks again for all the help. This site is amazing. Sure makes repairs a lot easier.
Old 04-13-2017, 09:56 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Bump bump ...
1- 1200 in pieces
1- 1864 in pieces
