Old 01-16-2015, 09:11 AM
Mcamp Mcamp is offline
gold stripe is the 86
Old 01-16-2015, 09:35 AM
Really? Every 86 I've seen has had a red stripe like the 128
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-16-2015, 09:58 AM
red56turbo's Avatar
Nice 108!
Gold stripe=86
Green stripe=108/109
Red stripe=128/129
Blue stripe=149/169
CC from the factory put the stripes on to set off each "set" of cub probably. So it makes it easier to spot a cub from a distance, see what color stripe it has, gear shift or not, and guess what model it is. Unless the PO put the wrong decal on or the hood was swapped.............
Both 86's I used to have had the gold stripe. Tim, someone musta replaced the decal or hood.
Josh
Diesel Cub Cadets...........
Old 01-16-2015, 10:40 AM
BigB87's Avatar
BigB87 BigB87 is offline
Well that. Makes some sense now. Its just odd i had a 108 that was blue stripe. But idk
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 01-16-2015, 11:51 AM
red56turbo's Avatar
Someone probably replaced the hood on your old 108. Hoods are all the same and the model number is on the dash cowl. I've seen quite a few over the years with different hoods. I've seen quietline hoods on the 1x8/1x9 series as well.
Congrats again on the 108 you found. Looks like a keeper.
Josh
Old 01-16-2015, 12:36 PM
BigB87's Avatar
Very true. If i ever get the gear for my ingersoll ill work on the 108
Brandon
Old 01-16-2015, 04:47 PM
sawdustdad's Avatar
Nice 108 you picked up!
(My 108 had/has a green stripe...)
Old 01-16-2015, 07:21 PM
Lew/Alvy...what you boys talkin about? We need more info on that seat.
From what I've seen the seat he has pictured came on the later narrow frames and early wide frames before the 6 pad came out. Either one in great condition seems to be harder and harder to find, but that's what came on them, with a white pan. Always looking for more info on this kind of stuff.
