Old 01-13-2015, 03:09 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
I think you read something wrong, or maybe the info was incorrect. There is only 25# difference in listed weight..
That is more reasonable. I was looking at tractordata.com.
Old 01-13-2015, 03:26 PM
jimbob200521's Avatar
So, that said....
The 1864 by all rights should weigh in far less. It has plastic hoods and a CH motor weighs a LOT less than the KT's or Magnums. Aluminum rear makes a difference too, although there is no listed weight difference between an early 782 and a late. Even the 1711 is listed at the same weight.
Travis nailed it. The 782 listed weight (855#) was with a 175# operator and full of fuel. The 1864 was listed at 880# with a 175# operator, full fuel (remember it also holds more fuel than a 782 by one gallon) and a 54" deck. So really...... 1864 weighs less. Quite a bit less. Like about 200# less.
I also want to note: The 1864 and 782 frames are identical. The difference in length is in the front axle. It has a more swept forward design. Always assumed that was for the tighter steering radius and also to make getting the 54" deck easier to remove/install.
Wow, great bit of info well said there. I didn't know the listed weight for an 1864 was with a 54" deck. Kinda weird they listed it with a 175lb operator and deck but it is what it is. Also nice to know when adding up all the weights on my 1864 that driver weight is included but I have to subtract deck weight :-/
-Ryan
Old 01-13-2015, 03:37 PM
Sorry guys, I goofed. The 1864 weight isn't with an operator. All other weights in the book are with an operator, I didn't read the rest of the sentence. So, the 1864 weighs 880# with a 54" deck. No operator. I don't know about fuel. It isn't specified one way or another. Most all equipment weights are given as "operating weight" which means full of fuel/fluids. Again, I apologize for incorrect info.
