Old 03-29-2010, 09:33 PM
Lmercer Lmercer is offline
Originally Posted by Mountain Heritage View Post
Not to sound rude.....but how dirty was it if you found this disk all of a sudden afterwards? Did small animals live in it before washing??? Could you even see under the sheet metal and engine or tranny?
Fair question: FILTHY
It is 2 1/2" OD and 1 5/8" ID
Old 03-29-2010, 10:03 PM
JayBrd's Avatar
JayBrd JayBrd is offline
You sure that is not a carb spacer of some kind?
Jay N.
Eau Claire, WI
RED 82 Series...
Old 03-29-2010, 10:15 PM
It's possible that it fell off the air cleaner when I took it off. I have never noticed it before on the back of the AC, but I don't look at it very much except to make sure the gasket's ok.
Old 03-29-2010, 10:49 PM
thenrie's Avatar
thenrie thenrie is offline
I'm thinking it goes on the back of the air cleaner housing, but I'm not sure. I've got my 1650 apart, so I'll look tomorrow and see if I can help you out.
Tony
Stafford, VA
1650, 682...
Old 03-29-2010, 10:55 PM
If that's the piece I'm thinking of, it goes over the inner part of the air cleaner housing that's bolted to the carb. It's about the right size. The bolts go through it, the rear air cleaner plate, and into the carb body.
Old 03-29-2010, 11:35 PM
nix1650's Avatar
nix1650 nix1650 is offline
Smile
I think Matt is right.
Old 03-31-2010, 09:03 AM
Default Mystery Solved
It's the same size as the gasket for the air cleaner to the carb. It just evidently hasn't been on there for quite some time as it is filthy on both sides
Old 03-31-2010, 09:39 AM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
You guys are right, that is the gasket that goes between the carb and air cleaner. I just took mine off last night, saw this pic and knew exactly what it was.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
