Snowthrower/Blower auger bearing W/Locking Collar Set of 2
PN/ IH-475698-R91 USE IH-214366-C92 & IH-455102-R21 USE IH-455102-R22 Fits models BB36, CC36, CC42, CW36, QA36, QA42, QA36A, QA42A, and QA36B. Like I said many of those parts interchanged on some of the throwers.
Nothing runs like a Deere with a Cub on its tail ! |
IH - Used Snow Thrower small Bevel Pinion Gear PN/ IH-475604-R1
Fits CW36,CC36, CC42, QA36,QA42, QA36A, and QA42A blowers
![]() Quote:
While I appreciate that you have bought from that seller, and the description says it will work..... they are still incorrect. If I must I will post pics of the parts books and the boxes that I currently have apart. I am quite certain. Also, no links posted so I can't see what ad you are referring to. The CW box uses four sealed bearings of the same thickness with no oil seals. The QA box uses two sealed bearings and two open bearings with two seals. The sealed and non sealed bearings in the QA box are different thicknesses. You cannot use the thinner bearing in the CW box unless you want to add shims as the shaft will have no way to "stay put" and move in and out of the bearings thus moving the gears apart inside and stopping all movement. |
We will have to agree to disagree here....no biggie ! I guess my CW was bullt incorrectly from the factory then because its not like you just explained for the CW thrower....its all good im done offering suggestions here....I will sit back with my popcorn and watch the show
![]() Have a great day ![]()
Ok.....
What are we agreeing to disagree on? That you have a CW thrower with the incorrect gear box? Or that the parts book for the CW thrower is incorrect? Here's the pic from the book for a CW gear box: Reference #12 is the bearing: 475-627-R91 CW36.jpg Here is the gearbox for a QA36A/42A thrower: Reference #16 for the bearing lists an inner and an outer bearing with separate part numbers. Inner: 475-627-R91 Outer: 475-628-R91 Note, there is no seal. QA36-42.jpg Then, we come to the QA36AQ/42A: Reference #10, Inner Bearing: 475-628-R91 Reference #9, Outer bearing: 475-627-R91 Reference #12, Seal: 485-306-R1 QA36A-42A.gif Please note: The sealed bearing is the same in ALL THREE gear boxes, except that the CW box contains four of them instead of just two like the other throwers. The gear boxes for the CC and BB throwers are the same as the CW. |
Think I shall have another bowl of popcorn....
Cool thread, Amy you can have the pop corn I'm headed for the Scotch. It's 5:00 somewhere.
Lmfao....scotch sounds good im headed for the eagles for a drink and dinner....enjoy the scotch
