Old 12-07-2014, 07:38 PM
Greasy Greasy is offline
Needle valve keeps sticking up, I've had it apart 4 or 5 times now...
Old 12-07-2014, 07:47 PM
You can check and see if the valve is replaceable, but I've not seen one that was. Does it have a rubber tip?
I'd rather one stick closed than open..... less messy, more frustrating. LOL.
Old 12-07-2014, 07:50 PM
Yes rubber tip, sticks clued when I need it most. Happened the other week during a snow storm had to shovel everything by hand..
Old 12-07-2014, 08:33 PM
If it is sticking closed and the engine dies, a simple tap on the side of the bowl with a screwdriver handle will free it.
Old 12-07-2014, 08:35 PM
It continues to re stick and sometimes even rapping it don't free it..
Old 12-07-2014, 08:38 PM
Alright, well....... then go ahead and get another carb. Either a used one (Kohler/Carter) and rebuild it, or ebay..... whichever you want.
Old 12-07-2014, 08:40 PM
Gonna have to I guess, I also wanna look into finding a spring assist for the plow.. It's a bare the way it is..
Old 12-07-2014, 09:26 PM
Think you meant "bear". LOL
Check with the sponsors at the top, or place an ad in the "Wanted" section.
Old 12-08-2014, 07:05 AM
mickb72 mickb72 is offline
Default cub
Originally Posted by Greasy View Post
Well I do have that walboro carb. I see new carbs on ebay for the k241.. Anyone used them, less than 50 bucks brand new kinda songs good to me..
Call Kustom L&G in Minerva OH.(330-868-7875) They have the best aftermarket carb, around 80$. He works with the Chinese trying to get them right. Tell him a guy in Cambridge Oh told you. I bought an engine kit from them, He has better instructions and sends a better plug and points than the other guy. Mike
Old 12-08-2014, 04:54 PM
Merk Merk is offline
Yes it does say walbro on it! Does that help any?
There should be a carb rebuild kit for a Walbro carb. Are you dipping your carb in a carb cleaning solution?
There should be some numbers on the carb to tell you what carb you have. It sounds like you have the wrong carb rebuild kit.
Where are you getting your parts?
Project Uncle Dick
Cub Cadet 70
