Old 11-19-2014, 04:17 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Originally Posted by Mike McKown View Post
Do you still have summer gas in it? Old gas?
I've seen that before. the winter blend makes a huge difference
Old 11-19-2014, 06:45 PM
Mine wouldn't start for beans sitting outside in the cold weather. (147) It needed to start because I was going to use it for snow removal. I made room in my garage to keep it out of the weather/wind. It's an unheated garage but it does make a significant difference.
Old 11-19-2014, 08:53 PM
Merk Merk is offline
My 149 starts hard when the temp is below 30 degrees. I did disconnect the drive shaft and it starts. One thing you need to remember you are spinning the hydraulic pump in the trans when you are starting the engine. The majority of the stored charge is going to turn the starter, engine and hydraulic system. There is not enough power left to for the spark plug to fire.
What weight oil do you have in the engine? Oil Kohler says to use is 10W-30 when temps are below 32 degrees.
Project Uncle Dick
Cub Cadet 70
Old 11-19-2014, 10:00 PM
I have also found something that helps with cold hard starts is: the correct weight of oil (10W 30), the highest CCA battery that will fit in the battery box (got mine at TSC) and I put a battery trickle tender charger on it anytime they are calling for snowfall. For the past 2 years this has worked. If it ever fails to turn over fast enough using this method, I'm going to go the magnetic heater under the rear end method.
Old 11-20-2014, 09:02 AM
charlie105's Avatar
charlie105 charlie105 is offline
Ditto drglinski's post, I did the same thingsto my 105,and replaced the coil with a Bosch Blue from Kirk engines inc. What a difference, and was able to open the plug gap to .032" from .025". But what I also find helpfull is disengaging the hydro with the lever on the tunnel cover so the starter is'nt driving the hydro pump. Don't know if the 149 has the same feature or not. Good luck, Steve
Old 11-20-2014, 09:31 AM
bullockcm bullockcm is offline
I agree with what everyone else is saying but don't overlook the little stuff. Case in point my 129 all the sudden didn't want to start this summer. I went over a bunch of things that wouldn't really have made sense only to finally discover the clip that holds the choke cable down by the carb had fallen off and the choke plate wasn't actually being controlled by the cable.
Old 11-20-2014, 09:57 AM
sawdustdad's Avatar
My 149 is particularly difficult to start because the hydro tends to engage more than my other hydros. I've adjusted the neutral on all the tractors, including the 149, but it still tends to engage when starting.
