Ok, you have to run the jumper that Y-Sam was talking about WITH IT RUNNING. You can't work on a charging system with the engine off. Only works when it's running, so no testing when off. Unless your ohm'ing wires. You can do that with the engine off.
If the points in the VR look that bad, just replace it. NOTE: The new one will look different. They had a design change. When you get the new one make sure you know how to wire it up. You going to have to make one of the wires a little longer IIRC. Been a year or so since I changed one on that series so my brain is a little rusty...... |
thanks
![]() ![]() Cub Cadet 108, IH snowthrower, IH ?? mower deck Cub Cadet 1650, IH 44 mower deck, IH snowthrower 1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake 1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow 1953 Ford Jubilee tractor and F100 Pickup
That the wiring is good and the charging system still is not working.
At this point it has to be the VR. THANKS FOR THE HELP!
It sounds like you are on to something with the corroded points in the regulator. I've never seen them worn away as badly as you describe, but I guess it's possible. When cleaning points of any kind I always use a point file rather than any kind of abrasive paper or cloth. I feel there is too great of a chance for mineral from the paper/cloth or other contaminates to get between the points, preventing contact. If you clean the contacts you should at least be able to make your situation better. Adjusting the regulator can be quite tedious and I don't recommend trying it if you aren't a very, very patient person. Only making the situation worse, is there are several different styles of V/R depending on vintage and manufacturer. This makes explaining the adjustment process extremely difficult.
When I polarize the Genny, the tractor starts up for a few seconds showing charge, then it drops to drain, turn on the lights and really drains.
I can try filing off the exposed rivet on the point contacts-nothing to loose. Also on the back of the vr, the fine wire wound around the cable to the "F" post is unwound and broke. that also might be causing problems. 1118981 is this the replacement for Delco 12 volt 4 post 108 cadet VR? thanks
Time to replace it. It seems roached for more than one reason. As stated above, be sure to wire new one correctly as wiring it incorrectly will sometimes let out the magic smoke that makes it work
NAPA sell them for a good price.
Part #7-016008
Up to 534 and counting... I give up updating my profile! |
terminals are not all labeled the same as my other and I am worried about hooking it up The "bat" and "f" terminal are the same as my old VR-Bat used to be in middle of 3 terminals. the "f" terminal also has the fine wire winding on the back of the new VR to a terminal under the VR on the opposite back side from the 3 terminal posts (looks to be ground maybe like my old VR) there is also an "l" terminal next to the battery terminal but no "gen" terminal -by deduction is guess "L" is replacing "gen" but i don't want to guess wrong and release magic smoke help!
"L" is for load. No it DOES NOT replace the "G" terminal. On most of the new ones the "G" terminal is the one on the rear. Post a pic of it. If you hook up the gen to the "L" terminal you will get a surprise. It will start cranking as soon as you hook up the battery.
