Ummm.... I wasn't trash talking. All I said was I have no idea what you are talking about. I'm sorry but I still don't. Sounds like this guy you are talking to is making something special. If you think it will work, then buy it. But without a pic, then we really can't help you. I fail to see what the problem is with the original style arm. They work fine, and you install it when you put the blower on, take it off when you remove the blower. It's only in the way if you put a mower deck on. I'm not sure if what on the cyclops machines you can't leave it on all the time. On the older machines, it hits the deck. I suggest you stay with the original design, and buy the one from extrememotorworks. We know it works.
ok first of all sorry to jonathan i understand why you want pics and links never heard back about special bracket just got it from extreme works great waited for snow got 8" the cub 1863 would not go 3' stuck real wet snow did not even get to check it out i got a new to me 451 that jmech hooked me up with i have wheel weight kit 190-370-100 75 lb. weight kit knew i should have had chains but tryed it anyway bad mistake ordered extra heavy 2 link chains from tirechains.com i am sure it will help but should i consider ballast also thanks in advance kenny
Either go with one from Extreme or have one made out of 3/4 inch flat bar because the cast ones from cub cadet can and will break. I've broken 2 cast ones pushing snow so I made one out of 1 inch flat bar and no more problems.
PGHsteelworker,
Could we see a bigger picture of that drawing please? Thanks, Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Guys, I think the bracket he is talking about is something like this (excuse the crude drawing). I've wondered why someone hasn't made one before but never did much looking into it. It's a single bracket to replace two; it replaces the blade lift bracket that rises above the foot rests and the snow blower lift bracket that drops below the foot rests with a single piece. This is where I believe the "one hole and one pin" statement comes from. If there is someone out there that makes one, I'd love to see a pic and if it's good quality I'd definitely be in for one.
-Ryan
I'm not sure if this will help or hurt peoples confusion but I found pics of both the brackets separate, and did a professional Photoshop mesh of the two for a simulated look of what he's talking about
-Ryan
I also bought a NOS blade lift arm only because the seller on epay dropped his price by $20 a few days ago. I don't have a need for it at the moment, but who knows what the future will hold! Maybe you should drop Aaron a line. He doesn't offer the blade lift. He could kill 2 birds with 1 stone. I would do $125 on that piece!Edit: don't forget to incorporate the height indicator like the OEM blade arm!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
![]() Send Xtreme an email after you send one the the patent office!
![]() If I had the tools/time, I'd just make it myself
-Ryan
I laid the NOS blade bracket on the xtrememotorworks blower bracket and this is what it looks like.
Edit: I have the blower bracket flipped the wrong way. Edit: or maybe not?
