Old 11-08-2014, 03:32 PM
Cub Cadet used a couple of different sizes of S/G pulleys.
Old 11-08-2014, 03:49 PM
garnold's Avatar
garnold garnold is offline
Could I get the dimensions of the pulley I should use. If I buy a new one I want to make sure it's correct.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 11-08-2014, 03:53 PM
According to the Parts Manual....you need KH-231278-S Pulley
Old 11-08-2014, 06:23 PM
The pulley is 3"in diameter on the WF S/G's
Looks like a blue belt on there,is it a stens?
Old 11-08-2014, 08:34 PM
I'm checking part numbers and the same belt (IH-401960-R1) seems to be used on both N/F and W/F so I don't think I bought the wrong one.
There was an assumption on my part, from the above statement, that he had the correct belt. Hmmmmmm maybe not????
Old 11-08-2014, 08:39 PM
garnold's Avatar
Correct, it is a blue belt. I'm going to order a CubCadet one and be sure. I did pick the correct one from the vender's site but maybe got the wrong one? Since this was my first time ordering one I really was not sure of the size and just expected it to be correct. Seems like something might have gotten messed up and I'm glad I asked you folks
73 WIP
75 WIP
Old 11-08-2014, 10:30 PM
garnold's Avatar
So I'm going to give this one a shot and see how things work out. It's a Cub product and not a 3rd party so maybe I'll have better luck?
http://www.ebay.com/itm/Old-Model-CU...-/201193114023
73 WIP
75 WIP
Old 11-08-2014, 11:27 PM
Calvins66Cub's Avatar
I believe the pulley on your S/G is the wrong one. There's a smaller pulley. I think that's the old style. Or just wrong. Pretty common. Ive got a couple big ones lying around I took off of Cubs.
It sounds like you got the right belt for your tractor, but you S/G pulley is not stock. I think you need a belt that is about 1" larger. Just my .02
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 11-09-2014, 07:39 AM
Gene, I ran into the same issue with my 108 and had the correct generator. I think IIRC I went through 3 different belts with that same number until I finally went to TSC and got a slightly longer belt, may have been 3/8 x 32 or 33. Mine was so tight that i could barely get the belt on and when I did I couldn't move the Pto engagement rod, not sure why this happened but I had the same issue
