Old 11-01-2014, 10:21 AM
Just sent you a PM
Old 11-01-2014, 11:03 AM
Group_44's Avatar
Group_44 Group_44 is offline
Thanks Sam, I got the manual pdf through the email. It looks like my firewall was blocking the download for some reason. I did come across this pdf during the search for the manual, it might be useful to the forum users to answer the never ending question "What Belt do I use for......" Maybe it can be posted in the technical info section of the forum.
http://www.cubcadet.info/Manuels/Bel..._1947-2004.pdf
Old 03-02-2026, 12:22 PM
Farmall450's Avatar
I wish someone saved this - link is dead.
Old 03-02-2026, 09:41 PM
Works for me.
Old 03-03-2026, 02:41 PM
Did you change the mule drive AND the hanging frame? or are you trying to hang the 54" deck from the 60" hanger frame and or mule drive?
I have both a 54 and a 60" for my 2182- I have to change everything to swap them over
I dont know if it means anything but in the parts catalog the 324 -54" mower uses mule drive with front hanger->703-2064 and the 374 60" mower uses the 385 mule which has a front hanger->703-0096 I admittedly dont know what the difference is but if you are trying to use the 60" mule drive and/or hanger on the 54" deck that might be the issue.
Old 03-07-2026, 09:10 PM
Farmall450's Avatar
I'm looking for the instructions for fitting a 54" 324 deck to my 2082. I removed the 60" deck for some badly needed repairs and want to put the 54" deck off my 2086 on until the end of the season and the blower gets put on. I put it on the way it came off the 2086 but it doesn't seem to hang correctly and looks too far forward ( right side front deck wheel fouls with tire in turns) . I just got the 2086 and have the engine out for service, I never got a chance to run the deck so I don't know if it was ever installed correctly. The 60" deck I took off the 2082 never seemed to lift high enough before I took it off. Both of these machines were second hand and neither was well cared for, I am not sure if either has the correct deck mount parts. I could use the manual to find out what holes in the mule drive to hang the mounts from.
For future readers of this - the super holes for the 2 lift links are the hole closest to the deck "fork". If you look at OP's first picture, the links aren't vertical because they're in the GT holes, not the SGT holes.
