Look at post #46-54. I repaired the same problem.
http://www.onlycubcadets.net/forum/s...ad.php?t=18287
CC 1450, 44A deck, #2 tiller, 42" plow/blade CC 124 CC 1220 #2 Cart |
Thanks for your help again; we got the differential housing switched out and she's running! I'm bothered by the fact that though both housings are said to be the same model number, the one has the hole in it for the internal brakes and the other does not. The swap went just fine, and I stayed with the external though I could have used either. It's still got a few bugs to work out (the plug won't spark until after you turn the key back to the on position, the battery isn't charging as well as it should, the lighting system needs to be overhauled, it slowly backs up when you let off on the brake, the speed control lever is pretty hard to move, and the pto clutch is seized up), but after sitting in the weather for so many years I'm very happy with our progress! Here's a couple pictures for your enjoyment.
Also, I've found that if you accidentally move the speed control lever from half speed to full speed to quickly, due to the sticky lever, the 169 will wheelie and about buck you off. Talk about torque!
Russell Cub Cadet Original w/ 3pt Cub Cadet Original w/ fenders, creeper, & 3pt Cub 100 w/ 3pt Cub 125 w/ 3pt NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller |
Kaleb,
Here's a link on how to test the starter/generator and the Voltage regulator. I found the link through the old forum webpages: http://s6.zetaboards.com/Only_Cub_Ca...opic/585322/1/ We should do this sometime! I haven't ever done this.
Russell, you'll have to swing by sometime and try it out for sure. I'm pretty excited to keep on improving it!
