Old 10-22-2014, 11:43 PM
Glad to hear it's running
Old 10-23-2014, 12:04 AM
Glad to hear you got it running! Go ahead and run 30wt oil. That's all I run in mine.
Old 10-23-2014, 12:06 AM
NE149's Avatar
NE149 NE149 is offline
That's what I had thought
Any suggestions for an exhaust elbow? I've been trying to find a threaded pipe elbow at local hardware stores with no success...
Old 10-23-2014, 12:07 AM
You just putting a regular muffler on it? Or a stack?
Old 10-23-2014, 12:08 AM
bocephus1991's Avatar
So Jon , thought you used brad penn oil to break an engine in . Are you saying it's ok to use standard or low ash 30W?
Brian
Old 10-23-2014, 12:09 AM
NE149's Avatar
I want to put a stack on... does the stack need a muffler? For the sake of back pressure? I don't care about noise... I'm young and learned early to wear ear plugs for everything :P
Old 10-23-2014, 12:11 AM
I break engines in on the same oil as I'm going to run in it. I don't use synthetic. Penzoil 30wt or Rotella 30wt is what I run in all my Kohler engines. Standard, low ash.... doesn't matter.
Hope I understood your question right..... Is that what you wanted to know?
Old 10-23-2014, 12:15 AM
No, doesn't need a muffler for back pressure. There is truth to getting a stack on and the carb tuned. A stack can affect HP. On a stock motor, I doubt any that you will notice, I'm just saying. Anyway, hardware store should have what you need. I don't see why you can't find any. It's just 1" pipe. I suggest a long sweep, or 2 45°'s to make a 90°. That way it's not so abrupt of a turn for the exhaust gas.
Old 10-23-2014, 12:17 AM
NE149's Avatar
Well the problem is finding a 1" threaded elbow that doesnt have a female end on it..l just want a male threaded end with bare pipe so I can weld a couple together and a stack... eh?
Old 10-23-2014, 12:18 AM
Yep that's what I was asking. I'm gonna use IH low ash oil in mine to break it in and use in it. I haven't had time to finish assembling it, been working about 60 70 hrs a week. Thanks Jon !
Brian
