Old 10-16-2014, 03:15 PM
Just don't put so much on the big one......
Old 10-16-2014, 03:21 PM
Steve149's Avatar
Steve149 Steve149 is offline
That's even worse. Now, you have leverage, and you only have 2 bolts in it.... advantage is there are more bolts holding the tiller mount on than the drawbar. I'd take some of the wood off the trailer.
I agree that is your weakest point and if the bolts break out of the case...well "Farewell and adieu..." As good as a CUB is they do have limitations!
Old 10-16-2014, 05:29 PM
cubby102's Avatar
cubby102 cubby102 is offline
Tracti on is gonna be your main issue. Myself personally I pulled my 16ft utility trailer loaded 4feet high with split firewood covering the whole deck. BUT the 1450 was extreamly light in the nose and wouldn't have done it if I were able to get my truck back to it. I also have a home made reciver hitch on it as well. Im sure I had it way over loaded but I had to do what I had to do. I wouldnt recommend it but it is possible to handle quite a bit
Old 10-19-2014, 09:03 AM
Mike1450's Avatar
Mike1450 Mike1450 is offline
I have the same set up on my 1450 and used it for yeasr pulling a 18 ft fiber glass boat around the yard to park it. Tongue weight of the boat was 250 lbs.
Old 10-19-2014, 10:00 AM
cadzag72 cadzag72 is offline
With my carts and trailers, I try to load them so a little more than half the weight is behind the axle, that helps cut back on the tongue weight.
Ian
Old 10-19-2014, 01:37 PM
johncub7172's Avatar
Thumbs up
Here is more of a real answer. However it's not using a hydro, which will never equal the same energy transfer as that of a all-gear IH Cub Cadet.
I towed an estimated 2000 + pound yard roller with my model 71 with k161AS. There was never any made up broken bolts in the rear plate cover. As a matter of fact, the yard roller pressed down on the draw bar and bent it down.
Real life experience. IH Cub Cadets are number one. Fact!
Old 10-19-2014, 04:07 PM
I just want to comment and say that I like the shed
Old 10-19-2014, 09:10 PM
cubby102's Avatar
I overload mine all the time but if I break it I usually have the parts to fix it. Helps using this also
Old 10-20-2014, 12:41 PM
OldCubby OldCubby is offline
OHHH i like that!!!
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 10-20-2014, 02:10 PM
Stratmoore Farms Stratmoore Farms is offline
Due to the angle of the trailer in you photo, it is hard to tell how much trailer sits out behind the axle. Having said that, loading the trailer heavy to the back end will decrease your tongue weight.
I hauled this load of wood a few weeks ago with my 104. That trailer is has a 6'X12'X2' box on it and the load was rounded over. I started with the tongue weight pretty close to neutral, but had to add some weight back to the front to get traction in a few spots.
http://s673.photobucket.com/user/oak...zed_1.jpg.html
Christ died for you, live for Him!!!
Bob
