Old 10-09-2014, 08:17 PM
What are you trying to make it run on for gas? You really need to buy better stuff for it to run on. Looks nasty.
Old 10-09-2014, 08:30 PM
j4c11's Avatar
j4c11 j4c11 is offline
I swear I've only used 93 octane gas with sta-bil added fresh from the pump. I'm baffled , I rebuilt the carb about 4 months ago, I don't know how it's possible for so much crud to build up in 4 months. Maybe I need to buy gas elsewhere.
Old 10-09-2014, 09:05 PM
First off, stop using 93. Use 89. That gunk is water in the fuel. Try buying gas somewhere else. Does this thing ever sit outside? Where do you store your fuel? I think Sta-bil is a waste of money. Never use it. I don't have any fuel/carb problems either. ( No problems as in, maybe once every two or three years I have to take a carb apart and clean it.)
Old 10-09-2014, 09:14 PM
j4c11's Avatar
The tractors sit in the garage, the car sits outside . I store the fuel in the garage as well.I'm definitely buying gas elsewhere from now on, I spotted a gasoline station that sells ethanol free gas, I'll try that.
Old 10-09-2014, 09:18 PM
I run ethanol blended fuel, but it does tend to attract moisture. Try the regular gas and see if that helps. Clean that thing up and hopefully that will take care of the over-fueling.
My cubs sit inside, cars sit out too. LOL
Old 10-09-2014, 09:57 PM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
That's nasty. I've never seen build up like that in 4 months. How do your fuel filters look, did you ever clean the tank out?
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 10-09-2014, 10:13 PM
j4c11's Avatar
It doesn't have a fuel filter and I've never cleaned the tank. What's the best way to clean the tank?
Old 10-09-2014, 10:17 PM
Add a fuel filter.
With gasoline.
Old 10-09-2014, 10:19 PM
j4c11's Avatar
With gasoline.
Should be plenty clean then, I put gasoline in it all the time.
Old 10-09-2014, 10:39 PM
Well.... yeah... LOL.
If gas won't cut it, mineral spirits or laquer thinner should. Taking the tank off and sloshing gas in it usually will clean it up.
