Old 09-25-2014, 02:31 PM
Use the adjustment links in your first picture to level the deck side/side. Use the adjustment links in the second picture to adjust level fore/aft. The front should be slightly lower.
Old 09-25-2014, 02:38 PM
BigCat77's Avatar
BigCat77 BigCat77 is offline
Ok, I got the side to side but will need to get back under and lower the front a little bit.
Old 09-25-2014, 03:43 PM
BigCat77's Avatar
Also, there is a lot of down pressure to where you have to watch it because it will move that cam stop.
Old 09-25-2014, 04:28 PM
ironman's Avatar
ironman ironman is offline
Not sure what you mean by pressure moving the cam. As you can see in this picture the cam just rotates and the big hand knob locks it wherever you want it. The arm in front of the cam is attached to the rockshaft and it stops the rockshaft when it touches the cam and limits your deck. There is no pressure on the cam.
Old 09-25-2014, 11:35 PM
cubby102's Avatar
cubby102 cubby102 is offline
Might have the pin in to lock it into the lift arms under the tunnel that would be the only way you get down pressure
Old 09-26-2014, 09:14 AM
BigCat77's Avatar
When lowering the deck I have to watch the rockshaft and stop it when it touches the cam stop or it will continue to put force on the cam stop and eventually cause it to move and keep lowering.
Old 09-26-2014, 09:18 AM
BigCat77's Avatar
Are you referring to the Float lockout pin described on page 20 in this manual?
http://ccmanuals.info/pdf/QL%20Operators%20Manual.pdf
I was thinking that too but since this tractor is so new to me I had a hard time understanding the wording. The last paragraph on the left side on page 20 is where I get lost.
Old 09-26-2014, 09:49 AM
Yes, the float lock-out pin is what they are referring to. If it is installed, you need to remove it. You don't need it for mowing. Fact is, you really don't need them installed at all...... ever as far as I'm concerned.
Old 09-26-2014, 09:52 AM
BigCat77's Avatar
It is possible it was installed to run the tiller it came with?
Good to know, Im learning a lot.
Old 09-26-2014, 09:56 AM
No, someone probably installed it to use a front mounted blade. People think they need down pressure on a blade. In reality, all it does is bend the lift rod all to crap. Would do the same thing with a tiller. I for the life of me don't know why they made it to have down pressure. Maybe there is an attachment that it helped with, but I've seen all the CC attachments as far as I know, and own a good portion of them. I've never needed down pressure.
