Old 09-18-2014, 11:28 PM
Nah... Doesn't sound like it. People do stuff like that when they don't know how to properly lock a bearing lock collar. They probably just used the set screw without turning the collar and it kept falling out. I've seen stuff like that before.
When you reinstall, notice there is a second hole in the lock collar. That is where you hit it with a punch. You lock it in the direction of shaft rotation. Or in this case, counter-clockwise (when standing in front of the machine looking at it).
Old 09-18-2014, 11:30 PM
Originally Posted by 64fleetside View Post
Yeah,I tried both directions even held crank from turning with Visegrips on the old race , I thought something would turn loose but not yet. I've given up for the night maybe a longer soak with the penetrant will help.
That sounds interesting......
Just out of curiosity, how did you hold the vice grips, the punch and swing the hammer?
Old 09-18-2014, 11:33 PM
Had my 14 y/o hold the grips, yeah he trusts me!
Old 09-18-2014, 11:37 PM
darryljs's Avatar
darryljs darryljs is offline
I used a spanner wrench and gave it a good hard wrap with a hammer, Works better than a punch.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 09-18-2014, 11:42 PM
That's a good way to break a spanner wrench.
Old 09-18-2014, 11:43 PM
Good idea, I've got some of those for setting the shocks on wheelers. I'll give it another shot tomorrow after'work. I had the bearing on the shelf at the part store I run, its used on balers/machinery shafts etc.
darryljs's Avatar
Here's what I used.
Old 09-18-2014, 11:53 PM
This is a late 74 model #:529554 it has the brake setup, some of which is kinda chewed, how important is it? The front disc which is held on by an e clip is kinda blue from heat.
Old 09-19-2014, 01:50 AM
This set screw was really too long and actually had a jam nut on it which is not shown in the manual nor included with the new bearing.
I hope it hasn't been "field engineered".
Something in there had a longer set screw and jam nut, was it the bearing collar or the basket and pulley?
Old 09-19-2014, 07:32 AM
The bearing collar had a set screw about twice as long as the new hearing collar, and had a jam nut.
