Old 08-17-2014, 01:27 AM
bocephus1991's Avatar
Put a 16hp in it you want more power
Brian
Old 08-17-2014, 01:42 AM
HoundDog's Avatar
HoundDog HoundDog is offline
I'll leave it alone
Restored 1970 127
1962 Original
Old 08-17-2014, 10:49 AM
Bob95065 Bob95065 is offline
David Kirk wrote a 3-part series on how he built his "Killer Kohler". There are some bolt-on parts but it mostly describes internal engine work.
http://www.kirkengines.com/ The article links are in the right column toward the bottom. Scroll down. He sells most of the performance parts you would need.
Old 08-17-2014, 11:54 AM
cubs-n-bxrs's Avatar
I think he was referring to bolt on mods and they are pretty much non existant.
Old 08-17-2014, 01:05 PM
Originally Posted by HoundDog View Post
None of that would hurt it? I read not to go over 3600 rpm. Just asking because I don't know and I want it to last a long time.
For the record.... no, it won't hurt it at all. I will say, if you still have the balance gears in it, you might want to take them out just so they don't grenade and cause problems.
Old 08-17-2014, 01:06 PM
The AG's I picked are 23/10.5/12. I do still want the new tires/wheels to fit with the mower deck.
I doubt that you will be able to get the mower deck on with 10.50 rears. I'd stick with the 8.50's. They make the same tires in both sizes.
Old 08-17-2014, 01:20 PM
HoundDog's Avatar
Looks like it has plenty of power the way it sits! I'm not messing with it!
Restored 1970 127
1962 Original
Old 08-17-2014, 01:26 PM
HoundDog's Avatar
I've been looking at aluminum wheels. All I can find are 12" wide wheels so far, and I know that's too wide. I'm guessing the stock rears are 7"-8" wide. If I can find an 8" wheel, I might be able to use the 10.50 AG tires, but only if I move the rear casters outward. On the other hand, I'm not sure if I want to still holes in my deck, either.....
Maybe I should just stop thinking about customizing it and leave it alone.
Restored 1970 127
1962 Original
Old 08-17-2014, 01:57 PM
It's a tractor, not a sports car. Leave it alone. Custom rims and tires are for pulling tractors and show cars, not for "worker" garden tractors.
Old 08-17-2014, 03:31 PM
782CC 782CC is offline
+ on the leave it alone concept. But if you do want more, the easiest way is chemicals. Toluene can perk it up a little. No more than a 10% mix. Or if more serious, try some Klotz Nitro additive.
https://www.klotzlube.com/techsheet.asp?ID=85
Tuning is needed for both with higher mixes. Both will clean valves/carbon and carbs. Nitro more so. The nitro can range from adding enough to bring a tired engine back to original HP. To LETS BLOW THE HEADS OFF. I personally kinda like that mode. lol Is important to stir the tanks if you let a mix set.
A little writeup on Nitro power adders.
http://www.racing-fuels.eu/nitro%20power.html
