Old 08-14-2014, 11:12 AM
PaulS's Avatar
PaulS PaulS is offline
Be sure it has the trip springs. Look at the bottom of the blade to be sure it has the cutter bar on it. be sure the mounting apparatis is what you need for your tractor.
Old 08-14-2014, 11:40 AM
Steve149's Avatar
Steve149 Steve149 is offline
The guy I am buying it from sold me my 149 and he says it will fit up correctly on the tractor...so we shall see. I just want to make sure I am getting everything I need as the trip is not conducive to running back in a few minutes cause something was forgotten.
Old 08-14-2014, 08:08 PM
Urbanfarmer Urbanfarmer is offline
Default Hardware
Sound like you are getting all you need.... there are some pin latches that are needed to hold it all on but other then that.... Sounds about what i got and its all there. Im going to need wheel weights and chains before winter though.
Old 08-14-2014, 09:54 PM
Keep in mind the scraper blade can be turned upside down for more use if it has excessive wear. I always set my blades up about 3/4" to prevent the scraper blade from getting worn down. I've used one of my blades a lot to move dirt this summer in landscaping and was proud of the way that my cub both pulled and pushed the dirt to level out the ground. Glad you made your purchase and hope you are as happy with the utility of the blade as what I am.
Old 08-15-2014, 11:45 AM
Steve149's Avatar
I got the plow last evening...it is a bit rough around the edges but it is complete. Just needs a bit of elbow grease to get her cleaned. I may try the electrolosys on the subframe.
I did hook the guy for a set of weights too Not IH but they will work.
Old 08-15-2014, 11:47 AM
Steve149's Avatar
Was amazed that the decal was in really good condition considering this guy had it setting out for god knows how long!
Needs de-rustified, but I am always up for a challenge! LOL
Old 08-15-2014, 12:21 PM
Stratmoore Farms Stratmoore Farms is offline
Nice find!!!
Christ died for you, live for Him!!!
Bob
Old 08-15-2014, 01:18 PM
Steve149's Avatar
I do have a question that maybe someone can answer...if you look at the picture the quick attach pin that is just in front of my right foot is bent slightly forward. It was getting dark and I don't think the pin itself is bent, but the flat steel part that the pin is attached to is. Could this be heated a bit and bent back to straighten it up with out causing any issues????
Old 08-15-2014, 10:36 PM
To answer your question, yes....but if you look carefully, your front of your subframe on that same side is bent inward, too! If you are just going to use it, then you my fit it up and see if it fits the way it is. If so, then I wouldn't bother messing with it unless it gets on your nerves. It didn't look bent to bad to me.
