Old 08-06-2014, 08:41 AM
4oz in 18 hrs!? ........ Nik, I wouldn't worry about it. It's a pint between add and full, and 4oz is 1/4, of 1 pint. No. Don't even try and find where it's going. You will pull your hair out and never find it. Your motor is fine.
Ahhhhhhhhh, my coffee taste soooooooooo much better this morning!
But, I'll still have a closer look this weekend if I see anything unusual.
NIK,
Give it an oil change and use 30W this time. My fav is Rotella T just my 2 cents.
Old 08-06-2014, 10:34 AM
nikster's Avatar
nikster nikster is offline
Hey, that sounds good. I'll see if 30w makes a difference?
Nik
Old 08-06-2014, 10:42 AM
jimbob200521's Avatar
That's got the 18hp Kohler Command in it, doesn't it?
Have you run a compression test on it to see what that tells you (may be a leaky/blown head gasket pulling oil into the chamber)? As far as oil usage, I've got 2 Commands right now (just passed another along with over 1500 hours on the clock) and none have burn oil. I've had 2 leak behind the PTO so I'd replace the seal, and be good to go again. Maybe take a closer look around the engine and see if oil is leaking out anywhere at such a slow pace you don't notice it. Sounds like a long shot, but never hurts to look closely.
Otherwise, I've heard these engines can be picky about oil. I personally never use multi weight oil during the spring/summer/fall, I stick to Rotella straight 30w (it's actually a diesel oil, less additives in it). In the winter, I may switch over to 5w-30 for the plow tractor, but probably not since I keep the machine in an enclosed garage and want to get a block heater. Anywho, maybe try a different oil, worth a shot.
Edit: With such low hours, I want to believe it's got to be something simple BUT if there is one thing I've learned, it's maintenance is the key to long engine life. So, I have to ask; any idea how the PO maintained it?
Nik
Sounds like good advice to me
-Ryan
